ASA NAT problem... help me.
shinwoo_acdc77
why not nat translation ... i don't understand.. please help me
==== config ====
nat (inside1) 1 10.10.10.0 255.255.255.0
nat (inside2) 1 10.10.11.0 255.255.255.0
global (outside) 1 192.168.1.1-192.168.1.100
some PC not connect to outside network
error message :
portmap translation creation failed
asa or pix bug?
sebastan_bach
Level 4
Level 4
for the number of nat sources ur pool is very small here u can configured dynamic nat. configure pat by specifying a single ip address.
u can also specify the a single ip address after the gobal pool u have specified.
so once the pool is full then the pix will pat the translations on that single ip.
hope this helps
regards
sebastan
vitripat
Level 7
Level 7
Here's what you need-
global (outside) 1 interface
As pointed out by Sebastan, your global pool seems too small to support both inside networks and hence we need to PAT using the above command. Hope that helps.
Vibhor.
