10-24-2006 05:15 AM - edited 03-13-2019 03:30 PM
4.13 with bunch of MGCP T1 PRI and FXO voice gateway.
We are going to have overhead broadcast at warehouse.
I have three questions, what is the benefit intergrate with CCM4.13??
And any suggestion about any overhead broadcast product (cost effective, easy to install, configure, easy intergrate with CCM and manage).
What kind of equipments (modules) that I need to intergrate with CCM4.13.
Ken
10-24-2006 06:18 AM
We use an Andtek solution. (www.andtek.com) in particular the andtek broadcast solution. Although this is typically restricted to an IP phone as the actual paging device. Just a thought.
10-24-2006 06:27 AM
I usually use Boegen self amplified speakers, and a Boegen UTI. Then all you need is an FXS card or an ATA. It is the cheapest way to do it if you are looking for overhead paging--if you want to use over the phone too; i agree with the other post or Berbee.
10-24-2006 09:09 AM
Agreed with the overhead stuff, but if anyone is looking for over the phone paging, Syn-Apps SA-announce is fantastic.
03-23-2011 01:30 PM
Does anybody know if the Bogen TAM-B is compatible with Cisco FXS module?
My client has ordered a couple of VIC3-4FXS/DID modules and wants to know if can be used to link the Bogen Paging solution via the TAM-B.
10-24-2006 06:46 AM
Hi Ken,
Here is a little added info to Dennis and Jans good posts;
Good paging tech notes
Using Analog E&M Ports to Interface to Overhead Paging Systems
http://www.cisco.com/warp/public/788/signalling/e_mpaging.html
Verify and Troubleshoot the Cisco IOS MGCP Gateway
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_tech_note09186a008017b2ad.shtml
The two most popular Overhead paging systems are Valcom and Bogen;
Valcom Paging
Valcom VoIP Paging
Bogen Paging
Hope this helps!
Rob
10-24-2006 08:22 AM
I believe if you use an FXS port off of the MGCP gtwy and connect it to your overhead paging amp. Typically the amp will be bogen or viking.
10-24-2006 08:39 AM
If you use an FXS port you will also need to use a Telephone Access Module (Bogen TAM-B) from each system.
10-24-2006 10:48 AM
all suggestions are great. I have also seen.. never have done it.... someone take apart a 7940 and stick it in the ceiling. They wired a speaker to the built in speaker and amplified it to the ceiling mounted speaker. Configured the 7940 using PLAR and whamo.... overhead paging.
enjoy todays hack of the day.
10-24-2006 01:07 PM
Hey Tommer,
I love that idea, all we need is some barbed wire and duct tape!!
Take care,
Rob
10-24-2006 03:05 PM
please rate if helpful.
(just jokin)
Did you see the one in the Unity forum? Guy wants the same thing, but for an MWI light in a general area... told him to take the phone apart and re-wire the Msg waiting lamp to a bigger bulb.
10-25-2006 05:06 AM
Ok guys, a lot of good idea... especially tacatinins' idea.
I am going to rate everyone that put 5 cents here.
Thanks a lot!!
Ken
10-25-2006 05:51 AM
Guys this is good stuff, I love the creativity and out of box thinking ;-)
