11-15-2002 03:03 PM - edited 03-12-2019 09:35 PM
Has anyone tried using RSVP over equal cost PVC's or Ethernet Interfaces . I found that it doesn't work I need to have a single path to a destination for it to work even though i had RSVP configured on all interfaces.
Solved! Go to Solution.
11-21-2002 01:39 PM
This will not work since RSVP is based on a single flow. In the restrictions related to RSVP it is clearly stated that there will be one recerved path and the sources should not use any other path other than the single reserved path.
11-21-2002 01:39 PM
11-21-2002 01:53 PM
Thanks for that
