Unity MWI problem
Steellllllllll0
Hi Guys,
I have just one user affected by MWI.Firstly it was stuck on but i dialled the mwi of dn to turn it off.Now it wont illuminate even tho there is an unread voicemail.I would like to resynch the mwi`s but cannot seem to find where to do it or proper documentation. Unity version is 1.0....thanks.
5 Replies 5
Rob Huffman
Hi Bruce,
If this is Unity Connection 1.x
This was provided by Unity Design Master Jeff Lindborg;
Under web admin under Tools | Task Management.
Selet the "Resynchronize MWIs On All Phone Systems"
Hope this helps!
Rob
Thanks for your help...found it ...
Hi Bruce,
You are most welcome :)
Take care,
Rob
Rob,
Can you do this during production? I'm having this same issue on Unity Connection 1.2. Thanks.
Hi Steve,
Here is the info for Unity (which I'm sure carries across to UC as well);
"We recommend choosing a time outside of regular business hours because of the Cisco Unity resources needed for resynchronization."
If you are really having serious issues you can schedule it to Run>Now but I would try to do it outside of production hours if at all possible :)
Hope this helps!
Rob
