11-29-2017 01:25 AM - edited 03-01-2019 08:40 AM
i try to use a nexus 5020 for voip applications. in my case with dante devices.
After approximately 3 minutes it seems to be the nexus switch is filtering all PTP packets and the VOIP/Dante devices are loosing sync.
system: version 5.2(1)N1(9a)
best regards
Christoph
Solved! Go to Solution.
12-01-2017 01:29 AM
Update:
I observed the first 3 minutes and afterwards.
I discovered igmp snooping as reason, because there was no igmp querier.
PTP packets filtered by igmp after 3 minutes -> audio devices out of sync.
disabeling igmp snooping -> audio devices are in sync
enabeling igmp snooping and add a igmp querier -> audio devices are in sync
thank yo for your support
11-29-2017 08:34 AM
Can you share the configuration?
11-29-2017 09:00 AM
Hi Rick,
i hope this is the information you need.
I got some basic knowledge of iOS, nx os is something new for me.
My intention is to use this older hardware for a Voip project.
best regards
Christoph
sh run
!Command: show running-config
!Time: Wed Nov 29 17:06:04 2017
feature fcoe
hostname n5k
system default switchport trunk mode auto
feature telnet
feature http-server
feature interface-vlan
feature lacp
feature lldp
feature fex
username admin password . role network-admin
banner motd #Nexus 5000 Switch
ip domain-lookup
fex 100
pinning max-links 1
description "FEX0100"
snmp-server user admin network-admin auth
priv localizedkey
ntp server 192.168.5.2 use-vrf management
vrf context management
ip route 0.0.0.0/0 192.168.5.1
vlan configuration 1
vlan 1
port-profile default max-ports 512
interface Vlan1
ip address 192.168.5.221/24
interface port-channel100
switchport mode fex-fabric
fex associate 100
interface fc2/1
interface fc2/2
interface fc2/3
interface fc2/4
interface fc2/5
interface fc2/6
interface fc3/1
interface fc3/2
interface fc3/3
interface fc3/4
interface fc3/5
interface fc3/6
interface Ethernet1/1
fex associate 100
channel-group 100
interface Ethernet1/2
fex associate 100
channel-group 100
interface Ethernet1/3
fex associate 100
channel-group 100
interface Ethernet1/4
fex associate 100
channel-group 100
interface Ethernet1/5
interface Ethernet1/6
interface Ethernet1/7
interface Ethernet1/8
interface Ethernet1/9
interface Ethernet1/10
interface Ethernet1/11
interface Ethernet1/12
interface Ethernet1/13
interface Ethernet1/14
interface Ethernet1/15
interface Ethernet1/16
interface Ethernet1/17
interface Ethernet1/18
interface Ethernet1/19
interface Ethernet1/20
interface Ethernet1/21
interface Ethernet1/22
interface Ethernet1/23
interface Ethernet1/24
interface Ethernet1/25
interface Ethernet1/26
interface Ethernet1/27
interface Ethernet1/28
interface Ethernet1/29
interface Ethernet1/30
interface Ethernet1/31
interface Ethernet1/32
interface Ethernet1/33
interface Ethernet1/34
interface Ethernet1/35
interface Ethernet1/36
interface Ethernet1/37
interface Ethernet1/38
interface Ethernet1/39
interface Ethernet1/40
interface mgmt0
ip address 192.168.5.200/24
interface Ethernet100/1/1
interface Ethernet100/1/2
interface Ethernet100/1/3
interface Ethernet100/1/4
interface Ethernet100/1/5
interface Ethernet100/1/6
interface Ethernet100/1/7
interface Ethernet100/1/8
interface Ethernet100/1/9
interface Ethernet100/1/10
interface Ethernet100/1/11
interface Ethernet100/1/12
interface Ethernet100/1/13
interface Ethernet100/1/14
interface Ethernet100/1/15
interface Ethernet100/1/16
interface Ethernet100/1/17
interface Ethernet100/1/18
interface Ethernet100/1/19
interface Ethernet100/1/20
interface Ethernet100/1/21
interface Ethernet100/1/22
interface Ethernet100/1/23
interface Ethernet100/1/24
interface Ethernet100/1/25
interface Ethernet100/1/26
interface Ethernet100/1/27
interface Ethernet100/1/28
interface Ethernet100/1/29
interface Ethernet100/1/30
interface Ethernet100/1/31
interface Ethernet100/1/32
system default zone default-zone permit
system default zone distribute full
line console
line vty
boot kickstart bootflash:/n5000-uk9-kickstart.5.2.1.N1.9a.bin
boot system bootflash:/n5000-uk9.5.2.1.N1.9a.bin
interface fc2/1
interface fc2/2
interface fc2/3
interface fc2/4
interface fc2/5
interface fc2/6
interface fc3/1
interface fc3/2
interface fc3/3
interface fc3/4
interface fc3/5
interface fc3/6
11-29-2017 09:09 AM
I don’t see ptp enabled. you would see “feature ptp” and “ ptp source xxx.xxx.xxx.xxx”
Do you have a ptp server you need to point to?
11-29-2017 09:19 AM
So i always need to activate the ptp feature and to define a ptp server.
If not the system will filter the ptp packets?
I already read about this topic on the cisco website.
iI think this message is part of my problem:
n5k(config)# feature ptp
ERROR: Feature PTP cannot be enabled in this platform.
n5k(config)#
Could it be a license problem?
best regards
Christoph
11-29-2017 09:26 AM
The Nexus requires L3 capabilities in order to support PTP.
PTP cannot be enabled on N5K-5020/5010.
11-29-2017 09:28 AM
11-29-2017 09:37 AM
Hi Wes,
that could be the solution. No layer 3 capabilities no ptp.
Thanks!
11-29-2017 09:27 AM
11-29-2017 09:33 AM
NTP is enabled
n5k(config)# sh feature
Feature Name Instance State
Flexlink 1 disabled
amt 1 disabled
bgp 1 disabled
cts 1 disabled
dhcp 1 disabled
dot1x 1 disabled
eigrp 1 disabled
eigrp 2 disabled
eigrp 3 disabled
eigrp 4 disabled
eth_port_sec 1 disabled
fabric-binding 1 disabled
fc-port-security 1 disabled
fcoe 1 enabled
fcoe-npv 1 disabled
fcsp 1 disabled
fex 1 enabled
fport-channel-trunk 1 disabled
glbp 1 disabled
hsrp_engine 1 disabled
http-server 1 enabled
interface-vlan 1 enabled
lacp 1 enabled
ldap 1 disabled
lldp 1 enabled
msdp 1 disabled
npiv 1 disabled
npv 1 disabled
oim 1 disabled
ospf 1 disabled
ospf 2 disabled
ospf 3 disabled
ospf 4 disabled
ospfv3 1 disabled
ospfv3 2 disabled
ospfv3 3 disabled
ospfv3 4 disabled
pim 1 disabled
pim6 1 disabled
poe 1 disabled
port_track 1 disabled
private-vlan 1 disabled
privilege 1 disabled
ptp 1 disabled
rip 1 disabled
rip 2 disabled
rip 3 disabled
rip 4 disabled
sshServer 1 enabled
tacacs 1 disabled
telnetServer 1 enabled
udld 1 disabled
vem 1 disabled
vpc 1 disabled
vrrp 1 disabled
vtp 1 disabled
11-29-2017 10:02 AM - edited 11-29-2017 10:05 AM
11-29-2017 11:47 AM
11-29-2017 11:55 AM
11-29-2017 11:59 AM
11-29-2017 12:21 PM - edited 11-29-2017 12:56 PM
Well, i try to explain how this audio network works. Sorry, my technical english isnt good.
The devices elect their master clock either by best quality or by maunal defining of a master device. So there is no dedicated ptp clock.
however, this sync is working for about approximately 3 minutes. Then the devices are out of sync. I recorded the traffic with wireshark and i recognized that the ptp v1 packets were removed after some minutes.
Thats why i belive this nexus is filtering something.
So i tried to create a simple configuration with only one fex and no qos.
