Catalyst 6500 - monitoring the temperature
alex.alexander
When monitoring a Catalyst 6500 temperature, which temperature in the show env temp has to be monitored?
Is it enough to monitor just one of them?
Or shall I monitor all the outputs?
Thanks in advance for any reply.
Alex
kmarrero
Level 4
Level 4
You should monitor all of them. In case you did not know, the numbers in parens are the (warning temp, critical temp) settings for that temp sensor.
