04-10-2003 11:51 AM - edited 03-02-2019 06:34 AM
I have this issue:
R2: running area 0 and 3 (ABR)
R1: running area 3 only (Internal router) and also is ASBR
I created a loopback interface on R1 assign ip address 150.50.200.1 and then
advertise this network in RIP. I then redistributed RIP into OSPF, hoping that I would see this route on my R2.
Area 3: 150.50.17.0/24
RIP is on 150.50.200.0/24
Redistribution commands.
rotuer ospf 1
redistribute RIP subnets metric-type I metric 20.
I don't know what I am doing wrong, but R2 is not seeing this route as an E2.
04-10-2003 12:14 PM
hi
You could try to do the following:
router ospf 1
redistribute connected subnets route-map "loopback"
route-map "loopback" permit 10
match ip address 50
access-list 10 permit 150.50.200.0 0.0.0.255
So you just redistribute connected networks and filter all except the loopback out.
Hope that helps
Roger
04-10-2003 12:18 PM
Thanks Roger !
I should have thought about this, but didn't click.
Thanks Again,
04-11-2003 10:06 AM
try to clear out your type 5 lsa's bu doing a 'clear ip ospf redistribution '
Also it would see it as an E1 because you are specifying metric-type 1
04-11-2003 01:26 PM
It still didn't work. Here is the configs.
r2#wr t
Building configuration...
Current configuration:
version 12.0
service timestamps debug uptime
service timestamps log uptime
hostname r2
ip subnet-zero
no ip domain-lookup
isdn switch-type basic-ni
interface Loopback0
ip address 200.0.0.2 255.255.255.255
no ip directed-broadcast
interface Ethernet0
ip address 150.50.17.2 255.255.255.0
media-type 10BaseT
interface Ethernet1
no ip address
shutdown
media-type 10BaseT
interface Serial0
no ip address
encapsulation frame-relay
no ip mroute-cache
logging event subif-link-status
logging event dlci-status-change
frame-relay lmi-type ansi
interface Serial0.24 point-to-point
ip address 150.50.24.2 255.255.255.0
frame-relay interface-dlci 103
interface Serial0.256 multipoint
ip address 150.50.100.2 255.255.255.224
ip ospf message-digest-key 1 md5 cisco
frame-relay map ip 150.50.100.2 102
frame-relay map ip 150.50.100.5 102 broadcast
frame-relay map ip 150.50.100.6 107 broadcast
interface Serial1
no ip address
ip ospf network broadcast
shutdown
interface Serial2
no ip address
shutdown
interface Serial3
no ip address
shutdown
interface BRI0
no ip address
dialer string 963-6000
interface BRI1
no ip address
shutdown
interface BRI2
no ip address
shutdown
interface BRI3
no ip address
shutdown
router ospf 1
area 0 authentication message-digest
network 150.50.17.2 0.0.0.0 area 3
network 150.50.24.2 0.0.0.0 area 1
network 150.50.100.2 0.0.0.0 area 0
network 200.0.0.2 0.0.0.0 area 22
neighbor 150.50.100.5
neighbor 150.50.100.6
ip classless
line con 0
transport input none
line aux 0
line vty 0 4
end
r2#
r1#wr t
Current configuration : 834 bytes
version 12.1
hostname r1
ip subnet-zero
no ip domain-lookup
interface Loopback0
ip address 200.0.0.1 255.255.255.255
interface Loopback10
ip address 150.50.200.1 255.255.255.0
interface Ethernet0/0
ip address 150.50.17.1 255.255.255.0
interface Serial0/0
no ip address
shutdown
no fair-queue
interface Serial0/1
no ip address
shutdown
router ospf 1
log-adjacency-changes
redistribute connected subnets route-map cisco
network 150.50.17.1 0.0.0.0 area 3
network 200.0.0.1 0.0.0.0 area 11
ip classless
ip http server
access-list 1 permit 150.50.200.0
route-map cisco permit 10
match ip address 1
route-map cisco permit 20
line con 0
line aux 0
line vty 0 4
no scheduler allocate
end
r1#
r2#show ip route
Codes: C - connected, S - static, I - IGRP, R - RIP, M - mobile, B - BGP
D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
E1 - OSPF external type 1, E2 - OSPF external type 2, E - EGP
i - IS-IS, L1 - IS-IS level-1, L2 - IS-IS level-2, * - candidate default
U - per-user static route, o - ODR
Gateway of last resort is not set
200.0.0.0/32 is subnetted, 5 subnets
C 200.0.0.2 is directly connected, Loopback0
O 200.0.0.4 [110/65] via 150.50.24.4, 01:54:08, Serial0.24
O 200.0.0.5 [110/65] via 150.50.24.4, 01:54:08, Serial0.24
O IA 200.0.0.6 [110/65] via 150.50.100.6, 00:07:22, Serial0.256
O IA 200.0.0.7 [110/75] via 150.50.100.5, 00:07:22, Serial0.256
10.0.0.0/24 is subnetted, 1 subnets
O 10.1.1.0 [110/74] via 150.50.24.4, 01:54:08, Serial0.24
O E2 192.168.1.0/24 [110/20] via 150.50.100.5, 00:07:22, Serial0.256
O E2 192.168.2.0/24 [110/20] via 150.50.100.5, 00:07:22, Serial0.256
150.50.0.0/16 is variably subnetted, 5 subnets, 3 masks
O 150.50.7.0/25 [110/74] via 150.50.100.5, 01:51:45, Serial0.256
C 150.50.17.0/24 is directly connected, Ethernet0
C 150.50.24.0/24 is directly connected, Serial0.24
C 150.50.100.0/27 is directly connected, Serial0.256
O IA 150.50.5.64/27 [110/138] via 150.50.100.5, 00:07:24, Serial0.256
O E2 192.168.3.0/24 [110/20] via 150.50.100.5, 00:07:24, Serial0.256
r2#
04-14-2003 04:42 AM
What does a ' sh ip o dat external 150.50.200.0 ' show ?
Also you referecne ACL 1 in your route-map , I do not see ACL 1 in your config
04-14-2003 05:11 AM
I would like to see a sho ip ospf neighbors on these routers. I dont think they are connecting. What does the wildcard 0.0.0.0 do on the ospf network statements?
04-14-2003 07:12 AM
i suppose that R1 and R2 are not OSPF neighbors..that's why R2 don't see routes from RIP route redistributed into OSPF
plz add "sho ip ospf nei" command output
thanks
04-14-2003 01:18 PM
add the command output for R1 and R2
show ip ospf nei
show ip ospf database
04-14-2003 01:34 PM
Thanks everbody in the forum ! I tried all the suggestions I received from you guys, but still couldn't make it to work. I checked configurations tons of times to see if there was any glitch. The weird thing was that R2 didn't have the entry for the route 150.50.200.0/24, but the routers beyond the R2 had that entry with default gatway through R2.
I got so frustrated that I erased both r1 and r2 completely, reloaded them and reconfigured them. Bingo! Everything is working now with the same configs I had before.
Anyway ! Thanks everyone for so responsive.
