how many split-tunnel entries I can give to one VPN group.
tonythacheth
I am using cisco 3845 as VPN router. I like to know how many split-tunnel entries I can give to one VPN group.
Tony
Jennifer Halim
You can assign 1 split tunnel access-list to one VPN group, however within the access-list, you can create multiple entries of access-list of the same ACL name/number.
My query is how many entries i can put in the split tunnel if i am using router as VPN concentrator.
50 entries is the limit for split tunnel.
Here is the bug for your reference: CSCsx60421
http://tools.cisco.com/Support/BugToolKit/search/getBugDetails.do?method=fetchBugDetails&bugId=CSCsx60421
