Cat6K VSS and blade switches.
bbaley
Level 3
Level 3
Can Cat 6K Virtual Switch Services be used to trunk blade server switches uplinks to separate switches.
Bill
jevogler
You can configure Etherchannel/PAgP from the blade switch to a VSS system*
*2 6500s with a VSL link between them
The blade server switch would think it was connected to a single device.
Here is a nice whitepaper:
http://www.cisco.com/en/US/prod/collateral/switches/ps5718/ps9336/prod_white_paper0900aecd806ee2ed.html
Current Blade switches can connect upstream two two VSS enabled switches and treat those two connections as an Etherchannel. Downstream, the two swtiches can not be etherchannelled together.
