problems configuring an E1 PRI, I can't get no more than 15 connections RDIS/modem in 3640
admin_2
Level 3
Level 3
I have a 3640 whith a network module 1FE-2CE1-B/U and one NM-12DM, for analog connections. In this moment the problem is that only 15 connections works ! when I try a 16 connection my modem doesn't connect the signal is ocupied !
my ios version is:
12.0(5)T1
here is an extract of my configuration
controller E1 1/1
pri-group timeslots 1-31
interface Serial1/1:15
no ip address
no ip directed-broadcast
encapsulation ppp
dialer rotary-group 1
isdn switch-type primary-net5
isdn incoming-voice modem
interface Group-Async1
ip unnumbered FastEthernet1/0
encapsulation ppp
ip tcp header-compression passive
async mode interactive
peer default ip address pool setup_pool
no cdp enable
ppp authentication pap
group-range 65 76
interface Dialer1
encapsulation ppp
dialer in-band
dialer-group 1
line 65 76
autoselect during-login
autoselect ppp
modem Dialin
modem autoconfigure type mica-noKflex
stopbits 1
flowcontrol hardware
maybe someone can help-me
Not applicable
Not sure what the problem is exactly;
you should be able to get a total of
12 async users and 18 sync users connected
at the same time. If you have a 13th
async user trying to connect, it won't
work since you don't have an available
modem.
If it looks like you have async users
that are connecting and then disconnecting,
but you don't see the line/modem being
cleared, then you first may want to try
upgrading your code (at least 12.0(7)T,
but latest 12.1 would be better).
