SG300-28P Running 1.3.7.18 - DHCP Problems
ian-heath
I have a SG300-28P running 1.3.7.18 which is configured in L3 mode.  This unit is running its DHCP service for my LAN hosts.
I've only set up a part of my /24 LAN subnet as the DHCP scope and have statically configured a number of LAN hosts to use specific IP addresses in this subnet, based on MAC address.  For these reserved addresses I have used addresses outside the range used for the DHCP scope.
Here's an example:
ip dhcp server
ip dhcp pool host some-host-1
address 192.168.1.10 255.255.255.0 hardware-address b8:c7:5d:c7:f9:5e
exit
ip dhcp pool host some-host-2
address 192.168.1.11 255.255.255.0 hardware-address 20:c9:d0:9a:a2:fb
exit
ip dhcp pool network LAN
address low 192.168.1.201 high 192.168.1.253 255.255.255.0
domain-name home.local
default-router 192.168.1.1
dns-server 208.67.222.222
exit
However, what I'm seeing is the static hosts are being allocated addresses from the 192.168.1.201 thru 253 block (with the MAC Address/Client Identifier being shown with the correct MAC address but with a "01:" prefix).
Also I'm seeing a few (declined) entries which look similar to this "192.168.1.210 Client Identifier c0.a8.6f.e2 2014-Mar-18 12:01:24 Dynamic Declined", i.e. with a MAC address with just a XX.XX.XX.XX hex format.
Any thoughts.
6 Replies 6
Tom Watts
Hi Ian, I believe you may not be using client identifer correctly. Use the client-identifer command and affix the 01 or the 00 in the command string.
client-identifer 01:20:c9:d0:9a:a2:fb
See if this will work.
-Tom Please mark answered for helpful posts http://blogs.cisco.com/smallbusiness/
Hi Tom,
I changed my statics from "hardware address <mac address>" to "client identifier 01:<mac address>" and that seems to work.  What I don't understand is what was wrong with my MAC address configuration.
Also I'm still seeing some strange declined entries with short MAC addresses (i.e. XX.XX.XX.XX).
Thanks again.
I've done some more testing.
So using "address <ip-address> <subnet> hardware-address <mac address>" doesn't work.
Using "address <ip-address> <subnet> client-identifier 01<mac address>" does match the IP to the MAC but then the default gateway & dns settings are not inherited from the DHCP scope.
so I have to have configuration like this for every static host:
ip dhcp pool host <name>
address <ip-address> <mask> client-identifier 01<mac-address>
default-router <ip-address>
dns-server <ip-address>
exit
Hi Ian,
I did test this issue with my own switch. I got same issue as well.  Please contact Cisco support center. 1-866-606-1866
Moh
I am having almost the same problem on Cisco SG300-28.
-Single default VLAN1 in L3 with 192.168.100.x/24 network, Switch IP 192.168.100.254/24
-Router/ISP modem's running NAT with LAN IP 192.168.100.1/24
-DHCP configured and assigning IP addresses to client machines from start of pool
-But static reservations for client machines is NOT working with MAC/hardware addresses, haven't tried with Client IDs yet.
Q1-Is only option to configure static reservations is through client IDs?
Q2-If so what will be the client IDs for MacBookPro, iphones and android devices? (I understand that windows devices have client IDs as 00 & 01:MACaddress
Q3-Do I have to make each static entry with Default-Router & DNS for all devices when using Client IDs? (I already have pool configured to assign default gateway 192.168.100.1 and dns 8.8.8.8 , which works well with dynamic DHCP clients)
P.S. I am doing all configuration through GUI, am I missing out on any important feature via GUI?
FJQ
Matthias Link
ok - found a solution to a very similar, but not quite the same issue. So if someone has issues with assignind static ips via DHCP take a look at this post:
https://supportforums.cisco.com/discussion/11822701/sg500-dhcp-server-does-not-assign-predefined-static-ip-addresses-hosts
Long way short: Don't enter a "Client Name". That makes the difference!
Works like charm then... THANK YOU for this.
