12-04-2007 09:21 PM - edited 03-05-2019 07:49 PM
The real question is this. I know turning off STP can be dangerous, but my switch is actually connecting via one cable into the wall. Where it goes from there I'm not sure as I only manage the servers and PCs connected to my switch.
One day it stopped working and that's the error that showed up. Before then I was using it unmanaged and it was working fine.
If I can just disable STP, will that solve my problem? If not, what do I have to do to make this work? Each port connects to a machine on a different subnet, but they all got to the outside world over the same port connected into the wall. Each network has its own default gateway but I think they're virtual (I didn't set that up) so they all eventually end up at the same place. Any ideas?
12-04-2007 09:26 PM
configuring spanning-tree portfast on the "uplink" port would disable the normal spanning-tree mechanism.
12-04-2007 09:34 PM
But is it ok to do, that's what I really need to know.
12-04-2007 10:53 PM
If you are sure there is only ONE! uplink cabling, then it is ok. If you are not sure, than it is a risk to do it.
about den spanning tree log entry: i dont think that this is a problem. But if you would have more informations about that the configurationfrom both sides (your switchports and that one on the other side of the wall) would be necessary.
12-04-2007 10:56 PM
From my switch to the wall, there is only cable. There isn't even a second port on the wall. But I don't know what's going beyond the wall.
12-04-2007 10:59 PM
I think the best thing is that you try to get the information what is behind that wall ;)
12-05-2007 09:44 AM
Hi Steve,
I searched a docuemnt regarding the error captured by syslog. This is what it says.
Lets say there are 2 switches, 1 operating with PVST+ & one with Common STP. now these 2 switches have to be connected with dot1Q trunk on both ends with same native VLAN.
The switch with PVST+ sends BPDU which contains VLAN ID that helps it recognise the native vlans. In case of discrepancy, the corresponding ports are put into a "PVID-inconsistent" or "type-inconsistent" state, which effectively blocks the traffic in the corresponding VLAN on a corresponding port.
here is the link for your reference:
http://www.cisco.com/en/US/tech/tk389/tk621/technologies_tech_note09186a00801d11a0.shtml
how to avoid this porobably experts can answer.
12-05-2007 11:53 AM
Well, I got it working. All I had to do was filter BPDU messages.
