MGCP with PRI
zeeshan2007
Dear sir
I wannted to know that i m using MGCP with 2 PRI's . i want to fix some channels for inbound call and same for outbound call on PRI 1 same thing with my PRI2. is it possible if yes how ? and same with H.323 ?
it will be very appreciating for me
thanks waiting for yr prompt response
5 Replies 5
paolo bevilacqua
That is usually not necessary. Why do you want to do that ?
Also remember that for incoming into the router, switch decides which channel to use, and router cannot change it.
ok if i have calls in channels 0-9 . and at the same time channel 10 is busy for outbound call,does switch automatically switch the call on channel 11, 12 etc ?
sir i have requirement where i have to fix some channels for outbound call in my both PRI's?could u plz help me out?
thanks
Sure, channels are automatically selected in PRI, and you have nothing to worry about.
sir thanks again. but i have the Same question can i fix some channels for outbound call in PRI using MGCP ?
Also I have a question for you that you did not answered: why do you want to do that ?
