Missing Back-End on C-60 codec
Anthony Chan
this is what I am geting
is there anything i can do
20 Replies 20
John Regan
What version of software are you using?
Do you have both HTTP and HTTPS enabled or one of these disabled?  You could try enabling both and rebooting to see if this resolves your issue.
John
I am not able to access anything on the codec at all.  as far as I know http, https, telnet was enabled
when i try to telnet in it bumps me out
is there a back way into the codec thru serial with specific instructions to stop this message or reset?
thanks
FYI, Cisco TAC sending over a replacement codec for this error message
Question to all if you are experiencing Cisco Codecs having issues lately?
so far within this week we have had two C60 that needed replacements
Teck Chye Tang
Did you try to take a log from the serial port and see if the codec actually boots up properly?
Or did you try to break the boot and send the selectsw command and try selecting the other image if any.
was trying to find out how to break the boot but was not informed how to,
are you able to provide that set of instructions?
have not had a chance to connect thru serial port in what that is saying as well
would love to if had time but we needed the codec to be replaced to get a working one up and running
my only concern is eventhough am able to break the boot, there is no insurance that it will not happen again, correct?
Connect a serail cable to the codec, reboot the codec and you should see below (example from C60)
CPU:   e300c1, MPC8347_TBGA_EA, Rev: 3.0 at 600 MHz, CSB: 200 MHz
I2C:   ready
DRAM:  DDR2 RAM: 512 MiB
RAM data bus test       [PASS]
RAM address bus test    [PASS]
FLASH: 4 MiB
NAND:  2048 MiB
RTC:   2011-12-14 (Wednesday) - Time:  5:29:03
PCI Video Processor Detection   [PASS]
Casper main board
       Rev: F
       SN: PH0605615
       Object level: 08
       MAC: 00:50:60:82:2C:06
Casper video board
       Rev: C
       SN: PH0610492
       Object level: 05
Net:   TSEC0, TSEC1
Hwmon: 39
Eth:   Configure the external switch
Press 'b' to enter u-boot prompt
Press 'c' to stop autoboot:  0
Notice the last 2 lines, follow it and you should see the "Casper >" prompt for C60.  Then you can enter the selectsw command.
Connecting via the serial will enable you to see if the codec actually boots up properly.
connected thru serial but am getting garbage characters in using putty
what is the appropriate settings for serial connection?
SerialPort BaudRate
Specify the baud rate (data transmission rate, bits per second) for the COM 1 port on the codec. The
default value is 38400.
Connection parameters for the COM port: Data bits: 8; Parity: None; Stop bits: 1; Flow control: None.
You can find this in the admin guide.
So here is the log that was captured, at the end i get the login prompt, therefore am I assuming that it booted properly then?
U-Boot 2009.03-77 (Feb 15 2011 - 08:39:22) MPC83XX
Reset Status:
I2C:   ready
DRAM:  DDR2 RAM: 512 MB
FLASH:  4 MB
NAND:  2048 MiB
RTC:   2011-12-15 (Thursday) - Time:  3:20:35
CasperII main board
       Rev: B
       SN: PH1087129
       Object level: 06
       MAC: 00:50:60:83:BC:D4
CasperII video input board
       Rev: B
       SN: PH1088960
       Object level: 05
Net:   TSEC0, TSEC1
Hwmon: 37
       (phy1,reg0=0x1140)
yaffs: Mounting /flash
Setting up Davinci HD (00.10.00)... 675Mhz       [DONE]
Setting up Davinci HD (00.11.00)... 675Mhz       [DONE]
Setting up Davinci HD (00.12.00)...1015Mhz       [DONE]
Setting up Davinci HD (00.13.00)...1015Mhz       [DONE]
Setting up Davinci HD (00.14.00)...1015Mhz       [DONE]
Setting up Davinci HD (00.15.00)...1015Mhz       [DONE]
Copy /flash/active/arm/rootfs to 0x03000000...  [DONE]
Copy /flash/active/arm/kernel to 0x02000000...  [DONE]
Copy /flash/active/arm/u-boot.bin to 0x01000000...      [DONE]
Copy /flash/active/rootfs to 0x02000000...      [DONE]
Copy /flash/active/kernel to 0x01000000...      [DONE]
Copy /flash/active/dtb3 to 0x03000000...        [DONE]
save exit: isCheckpointed 1
## Booting kernel from Legacy Image at 01000000 ...
   Image Name:   Linux-2.6.25.1-129
   Created:      2010-06-22  11:27:30 UTC
   Image Type:   PowerPC Linux Kernel Image (gzip compressed)
   Data Size:    2040139 Bytes =  1.9 MB
   Load Address: 00000000
   Entry Point:  00000000
   Verifying Checksum ... OK
## Loading init Ramdisk from Legacy Image at 02000000 ...
   Image Name:   TANDBERG rootfs
   Created:      2010-06-22  11:38:43 UTC
   Image Type:   PowerPC Linux RAMDisk Image (gzip compressed)
   Data Size:    8569468 Bytes =  8.2 MB
## Flattened Device Tree blob at 03000000
   Booting using the fdt blob at 0x3000000
   Uncompressing Kernel Image ... OK
   Loading Ramdisk to 1e358000, end 1eb8427c ... OK
   Loading Device Tree to 007fb000, end 007ff296 ... OK
Using MPC8347 Saturn PPC machine description
Linux version 2.6.25.1-129 (kaa@rema.rd.tandberg.com) (gcc version 4.4.1 (GCC) ) #1 PREEMPT Tue Jun 22 13:27:27 CEST 2010
Found initrd at 0xde358000:0xdeb8427c
console [udbg0] enabled
setup_arch: bootmem
mpc8347_saturn_ppc_setup_arch()
Found MPC83xx PCI host bridge at 0x00000000e0008500. Firmware bus number: 0->0
PCI host bridge /soc8349@e0000000/pci@8500 (primary) ranges:
arch: exit
Zone PFN ranges:
  DMA             0 ->   131072
  Normal     131072 ->   131072
  HighMem    131072 ->   131072
Movable zone start PFN for each node
early_node_map[1] active PFN ranges
    0:        0 ->   131072
Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 130048
Kernel command line: basemount=/dev/mtdblock1 console=tty0,38400 mainboard=0x91 videoboard=0xa1 audioextboard=0xffffffff u-boot=2009.03-77
IPIC (128 IRQ sources) at fdffa700
PID hash table entries: 2048 (order: 11, 8192 bytes)
clocksource: timebase mult[5000002] shift[22] registered
Console: colour dummy device 80x25
console handover: boot [udbg0] -> real [tty0]
login:
yes, for this case.
So here is the wierd part, I did nothing to the codec, all we did was to power it off for at least 24hrs and when I plugged into the serial to check that is what i got from the log capture.
Question if it hangs like before, what would I be selecting from the options? and what needs to be done to resolve the original problem?
Would it be option 'b' or 'c'?
so now your codec is functioning normally without the error?  I am not sure of the cause either (did you btw enter the release key previously?) since there is no log to trace.
If you want to break the boot, press 'b' then follow by 'c' and you will get a prompt.  then from there, you can enter the selectsw command.
What I am suggesting is for you to choose the other software image if you encounter the issue.  It may/may not solve what you are facing intially.
no release key was entered prior to the error, the unit was left over night and next morning the error just showed up
connected a monitor to the codec thru the HDMI output to DVI monitor but am not getting any signal at all
trying to do factory default but cannot connect thru ethernet using cross-cable to the endpoint
so here is an update:
eventhough i am getting the root prompt from the serial connection indicating that everything is normal
when I am accessing thru the web portal of the codec it is still getting me the "Missing Backend" message
I am able to connect to codec thru ssh and get login prompt but it bounces me out when i try to log in
so wonder if there is anything else i can do to do a factory reset or reload software from boot process?
