Multicast Tools
Any good tools out there for MCAST?
jleon22
We use this and it works great!
http://cisco.com/en/US/products/ps6337/index.html
I've been reading about this, but Cisco's documentation is a little sparse... can I ask a couple of questions....?
Does this actively monitor the network and give you a warning when you there are problem, in the same way that Openview NNM gives you a RED icon on a map?
Is it very helpfull to track down problems?
Dave
It has many different levels of monitoring capabilities. I probably will not do it justice in short. Best to contact your Cisco Rep.
For example, you can get alarmed (snmp traps) when your multicast tree has changed.
Hope that helps.
Rate if this posts helps.
