03-24-2016 06:16 AM - edited 03-18-2019 05:44 AM
Hi Guys
I have a device Sony PCS serie CX80 and I need know the TMS version that support it.
Any idea?
TIA
Cristian
03-24-2016 07:19 AM
Sony PCS Series is supported until TMS 14.2, while the Sony PCS1 is supported until 14.4. You can still use the endpoints within TMS by adding them as an Unmanaged Endpoint (aka Room in earlier TMS versions) which will allow you to still schedule conferences with them, but directly managing the endpoint's configuration isn't supported after 14.2 and 14.4 respectively.
Refer to the TMS Release Notes for product support that has been added/removed, an extensive list has already been gathered by users in the forums here: endpoint-support-tms-14-and-tms-15.
03-24-2016 10:05 AM
Thank you Patrick Sparkman.
03-24-2016 11:15 AM
No problem. Don't forget to set your question as answered if you don't need anything else by marking relevant replies that helped, so to help others that have the same issue can find the solution.
