automate sip phones integration into cucm 8.x
Roger_Nakoiri
Hi ,
I must configure more than 100 cisco spa 500 and 300 phones into cucm 8.x as third party phones (SIP) and need to know if there is a process to automate the integration of these phones in cucm 8.x?
Thanks!
5 Replies 5
anchoudh
Level 9
Level 9
HI Roger,
Is Automatic Registration  (with specific rnage of Directory numbers, option under CCM) enabled option doesn't serve this purpose?
Anand
Please rate helpful posts !!
Robert Thomas
Level 7
Level 7
How are you adding this phones to CUCM? Third Party SIP Devices?
I think using BAT is your best option to go.
Hi Thomas,
i add the phones in CUCM as Third Party SIP Devices manually.
What is BAT?
Hi Roger,
BAT: Bulk Administrator Tool
https://learningnetwork.cisco.com/docs/DOC-4162
Hope it helps.
Anand
Pls rate helpful posts !!
BAT Stands for Bulk Administration Tool. It allows you to import a large amount of Devices by the use of Excel and Spreadsheets that you later on import on the CUCM.
This way you only need to provision the information on the Spreadsheet and BAT will create all the phones for you.
