CDR problem
we are having CCM 4.1 and we have problem with CDR report actually CCM not generate any kind of report from last 6 month ?? how we can resolve this issues ??
Jaime Valencia
Data is Absent in Reports Created by the CAR Tool
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_tech_note09186a008056bd4e.shtml
java
if this helps, please rate
java
I read the your document it's good , i think we are facing case 3 from your document so is it right process that that the we can remove our all old database and created new data from day onwards.? and yes then what are the steps for that we can remove all old CDR database..?
hey javalenc,
I'm facing this problem in a CUCM 5.1.3.8000-4 (CAR Reports with no data)
Do you know how I could fix this issue?
thanks,
Karl
