01-25-2008 07:06 AM - edited 03-18-2019 08:22 PM
I need to change the Transfer type for existing users and can not find the option to do this in Bulk Edit, have already update the subscriber template for users going forward..is this option available to me without having to do it on a user by user basis or getting them to update in Ciscopca? Thanks.
Solved! Go to Solution.
01-25-2008 07:20 AM
01-25-2008 07:16 AM
What version of Unity, it should be in Bulk Edit. I am checking again. I have 4.2.1
rlp
01-25-2008 07:19 AM
Unity 4.2.1 - the tool is the version that came with the install. perhaps I need to download a new version. LEt me know if you find it, I may just need that extra set of eyes. Thanks for responding.
01-25-2008 07:20 AM
It is the "Transfer" tab
you might have to play around with it
rlp
01-25-2008 07:28 AM
I've been staring at that all morning :>)...its cryptic but makes sense once you look at the HELP file (famous last words).
Enable Transfer. Select âtrueâ to enable transfers for all selected subscribers and âfalseâ to disable it. If you disable transfer here, Unity will not try to ring the subscriber's phone when a user dials their extension from the opening greeting for instance. If you enable transfer and the subscriber doesn't have a custom transfer string set on the âCall Transferâ page in the SA, their extensions number will be used (i.e. the value on the Profile page will be dialed directly).
