CME GUI Issue
abhishekbanik
hello,
when trying to access GUI from web page but getting blank page.
Configuration has been done on the router , also uploaded the GUI file on the flash memory, but when im trying to access through web browser nothing happens only blank page comes up.
Router - 2900
IOS version - 15.0(1)M3
CME Version - 7.1.1.0
GUI Version -7.1.0.0
Please let me know if im missing any steps
2 Accepted Solutions
Have you done
show flash | i cme-gui-124-24T.tar or show flash | i gui  ?
If you've done last one, then you've installed gui for CME wrongly.
1. First you need to extract files to flash from TFTP:
archive tar /xtract tftp:///cme-gui-124-24T.tar flash:
2. Then enable http server
ip http server
ip http authentication local
ip http path flash:/gui
telephony-service
web admin system name password
then do show flash | i gui anf there should be file named telephony_service.html (or similar) - open it in browser.
Any success here? Have tried my last recommendations?
12 Replies 12
Gajanan Pande
Abhi,
Was a " Write Memory " & Router reboot tried ?
GP.
not yet can you please tell me the what does  "write memory" command do.
Have you used tftp path command?
Which web page are you trying to access? (exact name of html file)
Hi ,
not yet tired tftp path command , can you please tell me what does this command do.
the page which i'm trying to access is https://routeripaddress/ccme,html
can you posts "show flash | i gui" output.
voicelab#show flash | i cme-gui-124-24T.tar
8       829440 Mar 20 2012 08:48:36 cme-gui-124-24T.tar
Please find the output
Have you done
ip http server
telephony-service
Hi ,
Thanks a lot for your help , yes it worked
Good that it helped.
paolo bevilacqua
Which browser are you using ? Try firefox or older IE.
IE 8
