11-19-2010 09:22 AM - edited 03-19-2019 01:57 AM
Hello community,
customer asks me whether I can change the "tone", which is played one time with dnd enabled, when a call comes in. Can you help me with this?
Actually I would so "Nope." ;-)
Thanks and regards,
Thomas
Solved! Go to Solution.
11-19-2010 09:34 AM
You can disable the tone by setting the DND Incoming Call Alert option on the device to Flash Only; however, you cannot change the tone if it plays. This is hard-coded in the locale on the phone.
11-19-2010 09:34 AM
