CUCM 7.0 and CUE compatibility
jtryan1
I am working on a project to upgrade an existing CUCM installation to CUCM 7.0. The client has several remote sites running CUE. Does anyone know the which versions of CUE are compatible with CUCM 7.0? I cannot find CUCM 7.0 listed in any of the matrices?
5 Replies 5
William Bell
Not an authoritative answer but I don't think the current release CUE is compatible with CUCM 7.0. Meaning, it probably wasn't tested for this compatibility.
Last I heard is that CUE 7.0.1 was planned for release Q4 of this year. Not the answer you are looking for, but I would suspect this is where compatibility would occur.
Bill
HTH -Bill (b) http://ucguerrilla.com (t) @ucguerrilla
officially support won't be provided until CUE 7.0 is out. it should be released early 2009.
i know there was some testing with 3.2.2 so you can try with that version but won't have support
java
if this helps, please rate
java
CUE 3.2 does support CUCM 7.0. This testing/support was done to create a compatible release at the time CUCM 7.0 was released.
The CUE Compatibility Matrix should be used as the primary source for this type of info on CUE. Its available at: http://www.cisco.com/en/US/partner/docs/voice_ip_comm/unity_exp/compatibility/cuecomp.htm
This document shows CUE 3.2.2 and 3.2.1 are support with CUCM 7.0:
http://www.cisco.com/en/US/docs/voice_ip_comm/unity_exp/compatibility/cuecomp.htm
Thanks. I found that Document.
