CUCM Lab enviroment
Hello, im getting ready to take the CIPT I exam and i installed a CUCM 6.0 on a virtual machine, but i have no clue hot to get to the GUI from the CLI,
I can ping my virtula machine from the host, but i cant access throug the brownser either.
And the book that im following " Implementing Cisco Unified Communications Manager Part 1 CIPT1 Authorized Self Study Guide" doesnt say anything about it.
Can anybody help me ?
Thanks in advance.
Cesar
Jaime Valencia
Make sure Tomcat is running, try restarting the service.
Open a web browser and type:
https://IP
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
That wasnt the problem but it put me on the correct direction, all the services are stoped so im doing a new installation, i was using 30 gb of hard disk i readed that i need 74 is that right?.
Id like to rate, but i cant see how with that link.
thanks
Cesar
Its ok now, i had the proxy enabled all this time, but thanks anyway
