06-01-2010 05:32 AM - edited 03-19-2019 01:01 AM
Hi All,
We need to establish a connection between CCm release 4.0 and UC 520.
configuration from CCM side: we configure a H323 gateway to go directly to UC520
configuration from UC side: it's a simple dial peer
dial-peer voice 1000 voip
destination-pattern 6567
session protocol sipv2
session target ipv4:10.0.100.90
dtmf-relay h245-alphanumeric
we can call normally from CM to UC, but from UC to CM the call failed.
Could you help on this please.
Mohamed Sherif
06-01-2010 10:32 AM
Howdy,
Can you verify the CSS on the h323 gateway is configured?
06-01-2010 10:40 PM
Hi Kevin,
We don't have any calling search space configured in the call manager, current configuration is none.
Mohamed Sherif
06-01-2010 11:43 AM
Make sure you have the command:
h323-gateway voip bind sr
That IP needs to match what you configured in CUCM under H323 GW.
EDIT: just as an FYI this is NOT supported.
Q. Can the Cisco Unified Communications 500 Series be networked with Cisco Unified
CME or Cisco Unified Communications Manager?
A. The Cisco Unified Communications 500 Series can be networked with an integrated services
router-based Cisco Unified CME, but the Cisco Unified Communications 500 Series does not
work with Cisco Unified Communications Manager.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
06-01-2010 10:44 PM
Hi javalenc
This command is there
h323-gateway voip bind srcaddr 10.1.2.1
10.1.2.1 is the same IP configured under H323 GW
Mohamed Sherif
06-02-2010 12:13 AM
It seems you are trying to integrate via the Voice gateway running SIP towards the UC520.
You will need to create similar dial-peer pointing to CM from the voice gateway and make sure this gateway has the following commands:
voice services voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
gateway
interface
h323-gateway voip interface
Ensure this IP address is added as H.323 gateway in CCM and have incoming CSS set (or if u are not using PT/CSS - none)
06-02-2010 12:24 AM
Hi Pratik,
these configuration is also there in the Voice Gateway
Mohamed Sherif
06-02-2010 12:30 AM
Hi Sherif,
Please post both configs on VG as well as UC520 side.
