07-23-2008 01:28 PM - edited 03-18-2019 09:21 PM
I know that the call manager 6.x will not do Silent Monitoring/Recording with the older 7940. Will it work with IPCC and the desktop agent, or am I screwed unless I purchase new phones?
07-28-2008 12:32 PM
Just to make sure you are asking about if the monitoring/recording feature of IPCC Express/CAD will work with the older 7940 phones?
If so, then yes, you should be able to use the 7940 for monitoring and recording. I have used this capability back in CRS 4.0(1) and forward with CAD and the 7960 phones. I don't see why the 7940 would be an issue since it uses the same firmware as the 7960.
07-29-2008 10:32 AM
Yes that is what I am asking. I know the older versions will work with the the 7940, I am using it now.
I am trying to get away with upgradeing call manager and IPCC without having to replace all of my phones at this time.
So I guess to simplfy my question, will the monitoring/recording work with the current version of IPPC express and the older 7940 phones.
07-29-2008 03:46 PM
Yes, CRS 4.x and 5.x will both work with CAD monitoring/recording and the 7940s out of the box. Only if you want to use UCM 6 for the task do you need the newer phones.
