12-27-2005 11:48 PM - edited 03-18-2019 05:26 PM
We have two ccm 3.3 and 4.0 .
CCM 3.3 already ingegrated to Unity 3.1 and working fine.Unity having 4 port license .All port utlized .
Now we want enable VM for ccm 4.0 server .Created VM port in CCM 4.0 and port status showing
Cisco Voice Mail Port: CiscoUM1-VI1 (Cisco Voice Mail Port)
Registration: Not Registered
IP Address: 10.91.2.131
How to proceed to enable VM for CCM 4.0
12-28-2005 05:01 AM
You have 2 ways to configure it.
1. You can split the ports among the 2 CCMs
2. You can keep the VM ports registered with one CCM, and use Intercluster Trunk to route the voicemail calls to another CCM, however you will need at least one VM port for MWI.
Chris
12-28-2005 10:12 PM
Chirs,
Thanks for info.
If i use 2 port per CCM .it will work fine or not .
In case i donot want WMI for CCM2 register IP phone .
How to procced.
Ranjan
12-28-2005 10:54 PM
On Unity, open UTIM. Drill down to the first callmanager cluster and highlight the last two rows of ports. The Remove Ports button should not be grayed out when you select the ports.
On the first ccm's ccmadmin page, delete the last two ports and make sure the forwarding logic is correct.
On Unity's UTIM, click Callmanager Integration, and go to the menu for Cluster and select New Cluster
The default name will be CiscoUM1-VI and this is probably the name you have for the first ccm cluster. You will call it CiscoUM2-VI or something else to prevent confusion.
If you have done one integration, having the second one is identical. The only change is in UTIM.
12-28-2005 11:29 PM
On unity V 3.1 ,not able to find the UTIM menu .
In control panel ->modem and phone -> advance ->Cisco unity CM TSP -> confiure
Able to view CCM1 and 4 VM port info.If i change no of port is 2 it diaplay only two vm port for CCM1.
Now if i chnage the port nos 2 in that menu and add CCM2 and allot VM port 2 and the name of port it will work or not ?.
Or how to procced
Ranjan
12-28-2005 11:47 PM
i done as per plan in the prievious mail .working fine .incase any query i will revert back.
Ranjan
12-29-2005 02:56 AM
Now VM working in Both CCM 1 and CCM 2 .
I have issue
1.Not able to access the VM for CCM 2 register phones through Ip Phones .But VM delivery to user by mail.
2.MWI not working for CCM 2 .Created WMI 3000/3001 for on /off .same entry given in Unity -CCM-TSP property page .
How to reslove the same
Ranjan
