09-02-2010 01:11 PM - last edited on 03-25-2019 10:53 PM by ciscomoderator
Trying to configure SSL VPN on my UC520(8.0.4) through CCA 2.2.5.
I've gone through all the related tabs and sections in CCA for SSL VPN, but it doesn't seem to be working.
Thanks in advance.
Brian
Solved! Go to Solution.
09-07-2010 01:35 PM
SSL-VPN is covered in our Remote Workers application note.
SBCS 2.0 Application Note: Adding Remote Workers
http://tools.cisco.com/s2slv2/ViewDocument?docName=EXT-AS-248733
This application note describes the mechanism for adding remote access VPN services (e.g.: Mobile workers, Remote offices, and Home offices) to an operational Cisco Smart Business Communications System (SBCS) network installed at the main office according to the guidelines described in the SBCS 2.0 Implementation Guide.
09-02-2010 01:20 PM
Try checking this...
09-02-2010 02:25 PM
This link you sent is for the phone VPN. I am trying to setup the SSL VPN for PC functionality. Is there a different doc?
-Brian
09-07-2010 01:35 PM
09-11-2010 03:52 PM
Thanks,.,.
