SPA8000: attended transfer with FLASH does not work
vieri.dipaola
I'm having trouble with attended transfers on phones connected to an SPA8000.
If an SPA phone A calls another SPA phone B which in turn, picks the call up and subsequently presses the R key (Flash) and dials another SPA extension C until C picks the phone up and B hangs up, then caller A can talk to caller C (attended transfer is OK).
However, if C is any other type of extension (SIP softphone, ZAP extension ¡, etc) then when B hangs up, the call to C drops and B "rings back" with caller A.
The only way I found to a successful attended transfer if C is not an SPA8000 extension is for B to dial *2 (Asterisk's built-in attended transfer feature).
If I compare the SPA8000 to Grandstream's GXW4008, with the latter, attended transfers with Flash work fine as described above. I would like to have the same behavior on the Linksys SPA8000. Is it possible?
paolo bevilacqua
I'm afraid you won't get an answer here.
The linksys voice system is virtually unknown to this forum community. I personally have setup one for a try once, but did not test much on it.
agreed, this is not a product that partners are keen on marketing
when I am trying to troubleshoot one of these SPA boxes I usually look to the voxilla.com forums, they have a linksys/sipura specific forum with lots of activity
hope this helps
Wow, I thought I was going to get "better support" out of Linksys/Cisco.
That's definitely a cold shower.
Thanks for suggesting voxilla. Will try over there.
