UC520 Can not complete conference
rawsonfang
I have UC520 the conference between three IP phones was working, but now stop working, this might caused by adding extra feature configuration into phone, but not sure what cause this conference stop working.
Double check the DSP registration, all seems fine, attached please find the full config. the extension 810, 811 and 820 were being used for three way conference. please advice.
KueiLuck-PBX#sh dsp all
Dspfarm Profile Configuration
Profile ID = 2, Service = TRANSCODING, Resource ID = 1
Profile Description :
Profile Service Mode : Non Secure
Profile Admin State : UP
Profile Operation State : ACTIVE
Application : SCCP   Status : ASSOCIATED
Resource Provider : FLEX_DSPRM   Status : UP
Number of Resource Configured : 2
Number of Resource Available : 2
Codec Configuration
Codec : g711ulaw, Maximum Packetization Period : 30
Codec : g711alaw, Maximum Packetization Period : 30
Codec : ilbc, Maximum Packetization Period : 60
Codec : g723r63, Maximum Packetization Period : 60
Codec : g723r53, Maximum Packetization Period : 60
Codec : gsmamr-nb, Maximum Packetization Period : 60
Codec : g729ar8, Maximum Packetization Period : 60
Codec : g729abr8, Maximum Packetization Period : 60
Profile ID = 1, Service = CONFERENCING, Resource ID = 2
Number of Resource Configured : 4
Number of Resource Available : 4
Codec Configuration
Codec : g711ulaw, Maximum Packetization Period : 30 , Transcoder: Not Required
Codec : g711alaw, Maximum Packetization Period : 30 , Transcoder: Not Required
Codec : g729ar8, Maximum Packetization Period : 60 , Transcoder: Not Required
Codec : g729abr8, Maximum Packetization Period : 60 , Transcoder: Not Required
Codec : g729r8, Maximum Packetization Period : 60 , Transcoder: Not Required
Codec : g729br8, Maximum Packetization Period : 60 , Transcoder: Not Required
SLOT DSP VERSION  STATUS CHNL USE   TYPE    RSC_ID BRIDGE_ID PKTS_TXED PKTS_RXED
0    2   21.4.3   UP     N/A  FREE  xcode  1      -         -         -
0    3   1.1.137  UP     N/A  FREE  conf   2      -         -         -
0    4   1.1.137  UP     N/A  FREE  conf   2      -         -         -
Total number of DSPFARM DSP channel(s) 6
KueiLuck-PBX#
KueiLuck-PBX#sh telephony-service
CONFIG (Version=4.2(0))
Version 4.2(0)
Cisco Unified Communications Manager Express
For on-line documentation please see:
www.cisco.com/univercd/cc/td/doc/product/access/ip_ph/ip_ks/index.htm source-address 10.1.1.1 port 2000
max-ephones 32
max-dn 128
max-conferences 3 gain -6
dspfarm units 5
dspfarm transcode sessions 2
dspfarm 1 CFB123456789123
dspfarm 2 MTP123456789123
dspfarm 3
dspfarm 4
dspfarm 5
conference hardware
hunt-group report delay 1 hours
hunt-group logout DND
max-redirect 5
voicemail 401
cnf-file location: system:
cnf-file option: PER-PHONE-TYPE
network-locale[0] US   (This is the default network locale for this box)
network-locale[1] US
network-locale[2] US
network-locale[3] US
network-locale[4] US
user-locale[0] US    (This is the default user locale for this box)
user-locale[1] US
user-locale[2] US
user-locale[3] US
user-locale[4] US
srst mode auto-provision is OFF
srst ephone template is 0
srst dn template is 0
srst dn line mode is single
phone service videoCapability 1
moh music-on-hold.au
time-format 24
date-format mm-dd-yy
timezone 13 US Eastern Standard Time
secondary-dialtone 9
url services http://10.1.10.1/voiceview/common/login.do
call-forward pattern .T
call-forward system redirecting-expanded
transfer-pattern 9.T
transfer-pattern .T
keepalive 30 auxiliary 30
timeout interdigit 5
timeout busy 10
timeout ringing 180
timeout ringin-callerid 8
timeout night-service-bell 12
caller-id name-only: enable
system message Kuei Luck Enrichment Center
web admin system name administrator  secret 5 $1$oeUe$YLlsbUaxga5BWwDi4TZbL.
web admin customer name Customer
edit DN through Web:  enabled.
edit TIME through web:  enabled.
Log (table parameters):
     max-size: 150
     retain-timer: 15
create cnf-files version-stamp 7960 Apr 07 2010 21:32:10
transfer-system full-consult dss
multicast moh 239.10.16.16 port 2000
auto assign 10 to 27
auto assign 5 to 8 type ANL
local directory service: enabled.
Extension-assigner tag-type ephone-tag.
ip
KueiLuck-PBX#
7 Replies 7
Once you change to hardware conferencing, all conferences (including three way) are handled by the on-board DSP's. You are missing the ad-hoc ephone-dn, that's why it doesn't work. More info on:
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/admin/configuration/guide/cmeconf.html#wp1011236
Marcos
Hi Marcos,
After putting in the "conference ad-hoc" command under ephone-dn 1 dual-line
but it not allow me to key in the "call-forward busy 401 ' and " call-forward noan 401 timout 10" for transfering call to voicemail pilot 401. Any thought? Thanks
You cannot do it on these existing DN's assigned to phones. You have to create new ephone-dn and these will just have that ad-hoc command.
Marcos
Hi Marcos,
I created a new DN, and it takes the conference ad-hoc command , but it did not take the "call-forward busy 401 and call-forward noan 401 timeout 10" commands, and claimed "Remove DN special mode configuration first", not sure what is means. following is the screen capture.
Please advise.
KueiLuck-PBX(config)#ephone-dn 12 dual-line
KueiLuck-PBX(config-ephone-dn)#
000101: Apr 17 14:10:07.611: %LINK-3-UPDOWN: Interface ephone_dsp DN 12.2, chang
ed state to up
000102: Apr 17 14:10:07.611: %LINK-3-UPDOWN: Interface ephone_dsp DN 12.1, chang
ed state to up
KueiLuck-PBX(config-ephone-dn)#con
KueiLuck-PBX(config-ephone-dn)#conference ?
ad-hoc Ad-hoc conference, at least 2 DNs must be configured
meetme Meetme conference, at least 2 DNs must be configured
KueiLuck-PBX(config-ephone-dn)#conference ad-hoc
Configure number first for DN 12!
KueiLuck-PBX(config-ephone-dn)#number 810 no-reg both
KueiLuck-PBX(config-ephone-dn)# pickup-group 1
KueiLuck-PBX(config-ephone-dn)# label 810
KueiLuck-PBX(config-ephone-dn)# description Kevin Kung
KueiLuck-PBX(config-ephone-dn)# name Kevin Kung
KueiLuck-PBX(config-ephone-dn)# call-forward busy 401
KueiLuck-PBX(config-ephone-dn)# call-forward noan 401 timeout 10
KueiLuck-PBX(config-ephone-dn)# huntstop channel
KueiLuck-PBX#sh run | section include ephone-dn 12 dual-line
pickup-group 1
label 810
name Kevin Kung
conference ad-hoc
huntstop channel
You need to remove all commands except "ad-hoc" and "number". It is explained in the document I sent.
Marcos
Is this means the hardware ad-hoc conference feature could not co-exist with the busy call-farward to voice mail pilot on that dn ? Thanks
Hi Marcos,
Ok, I just create for bogus dn for hardware conference only, and it works now, Thanks a lot for your help, configuration as following:
ephone-dn 51 dual-line
number A0001
name conference
conference ad-hoc
preference 1
no huntstop
ephone-dn 52 dual-line
number A0001
name conference
conference ad-hoc
preference 2
no huntstop
ephone-dn 53 dual-line
number A0001
name conference
conference ad-hoc
preference 3
no huntstop
ephone-dn 54 dual-line
number A0001
name conference
conference ad-hoc
preference 4
