02-25-2005 11:32 AM
I have a USR modem w/analog line connected to console port on Cisco 1721 or 2620XM router. Routers are running 12.3(12a) IP Plus images.
Problem: I cannot connect to the modem when it's connected to the router. However, when the modem is disconnected from the router, I can connect everytime. I'm not sure what is going on here, any ideas.
What command string is sent from the router to the modem upon connection or powerup?
line con 0
exec-timeout 5 0
password xxxx
login
transport preferred none
02-25-2005 12:11 PM
Please ensure that init string is correctly configured in the USR modem.
http://www.cisco.com/en/US/tech/tk801/tk36/technologies_tech_note09186a00800941c9.shtml
Thanks, Mak
02-27-2005 03:06 AM
Seem to remember to use "transport input all".
Found an example: http://www.cisco.com/en/US/tech/tk801/tk36/technologies_configuration_example09186a0080094579.shtml
There is alot more to it, then what you have done.
Hopefully the example will help you.
