02-14-2014 12:06 AM - edited 03-04-2019 10:20 PM
I have an issue where show env o/p is as below, I suspect the FAN 1 which shows failed is not present in router, how do i find out with the help of CLI , how many fans are present in router.
#show environment all
SYS PS1 is present.
Fan status: Normal
Input Voltage status: Normal
DC Output Voltage status: Normal
Type: AC
Thermal status: Normal
SYS PS2 is present.
Fan status: Normal
Type: AC
AUX(-48V) PS1 is absent.
AUX(-48V) PS2 is absent.
Fan 1 Failed
Fan 2 Normal
Fan 3 Normal
Fan Speed is Normal
Alert settings:
Intake temperature warning: Enabled, Threshold: 55 Core temperature warning: Enabled, Threshold: 70 (CPU: 90)
Board Temperature: Normal
Internal-ambient temperature = 28, Normal CPU temperature = 41, Normal Intake temperature = 22, Normal Backplane temperature = 19, Normal
Voltage 1(3300) is Normal, Current voltage = 3284 mV Voltage 2(5150) is Normal, Current voltage = 5153 mV Voltage 3(2500) is Normal, Current voltage = 2525 mV Voltage 4(1200) is Normal, Current voltage = 1203 mV
Nominal frequency
Solved! Go to Solution.
02-14-2014 02:29 AM
This means that FAN1 has failed.
Fan 1 Failed
Feb 14 07:31:01.996 GMT: %FAN-3-FAN_FAILED: Fan 1 had a rotation error reported.
Feb 14 07:31:21.996 GMT: %FAN-3-FAN_FAILED: Fan 1 had a rotation error reported.
Feb 14 07:31:41.995 GMT: %FAN-3-FAN_FAILED: Fan 1 had a rotation error reported.
Feb 14 07:32:01.994 GMT: %FAN-3-FAN_FAILED: Fan 1 had a rotation error reported. Feb 14 07:31:01.996 GMT: %FAN-3-FAN_FAILED: Fan 1 had a rotation error reported.
02-14-2014 12:48 AM
Why would it report it as failed if it wasn't present ?
Alain
02-14-2014 12:53 AM
Hi Alain,
I have seen in some devices when fan is not present it gives o/p as failed? and when i physically checked it was not there.
If at we consider its there inside, how do we can find out its presence, does failed means its presence there?
Arun
02-14-2014 01:10 AM
ok didn't know about this fact.
I don't see how you can do apart opening the device and verifying.
Alain
02-14-2014 01:14 AM
To make it more specific in SDM was getting alert as FAN 3 failed, where as FAN 3 was not there in the device and that was switch, and I do not recollect the command o/p where it showed me absent or something like that. So what my q is is there a CLI command which shows the number of FANS present in chasis. Simple rite?
02-14-2014 01:38 AM
yes simple indeed but aprt from the command you used I'm not aware of any other, maybe some more knowledgeable people will tell you if there is such a command then.
Alain
02-14-2014 01:41 AM
My second point is does failed confirms the presence of the FAN ?
02-14-2014 01:43 AM
I would have thought so but you tell that it may not be the case.
Alain
02-14-2014 01:47 AM
I would have provided you the proof of the it, but unfortunately the snapshot captured machine got crashed and I could not recover the data. But I am very much sure that I have seen it CLI mode where it showed me FAN is not present still i got the error log of failed FAN.
02-14-2014 02:07 AM
Arun,
Do you show any errors for the fan under 'show logging' ?
Also, "fan failed' should indicate the failure of a fan. But usually you should see errors under 'show logging'
02-14-2014 02:09 AM
yes it does as follows
Again My second point is whether failed means fan is present or absent ?
02-14-2014 02:29 AM
Fan 1 Failed
02-14-2014 02:51 AM
Thanks John,
08-06-2014 03:49 AM
Hi All,
In cisco 3845 router, we are using, in that totally 3 fan, but fan 1 is failed. how to find the serial no of the fan...By using the cli...
thank and Regards
Natarajan
