11-21-2006 07:02 AM - edited 07-03-2021 01:16 PM
Hi Guys,
Is there any way to use multiple 2000 series controllers together to controller more than 6 waps? Or do I have to upgrade to a 4400 series?
thanks
11-21-2006 07:16 AM
Hi Friend,
Single 2006 can control only 6 AP and there is no way you can cluster more than 1 2006 together.
So only option left with you is 4402 or 4404 controller.
Ankur
*Pls rate helpfull post
11-21-2006 07:29 AM
Thanks friend,
That answers my question.
12-07-2006 08:16 AM
You can configure multiple 2006 controllers in the same mobility group with the same virtual IP address. The 2006s will need to be connected to a switch. This is a very common deployment. However, you will have a different point of management for your second set of 6 access points - unless you have WCS.
The same scenario exists when customer need 50/100+ AP support and use multiple 4400 series controllers.
Please see the following url for additional information:
http://cco/en/US/products/ps6366/products_configuration_guide_chapter09186a008076cf0a.html
Mark
04-02-2007 12:17 PM
Thanks! I thought it could be done with mobility groups. I have been sitting on this one for a while.
