[mvpn ME3800/ASR9k]
Carlos A. Silva
Level 3
Level 3
I have an environment where you have a ME3800 and an ASR9000 as PEs for mVPN.
Within the VPN the control and data plane for ipv4 works just fine. That is I can ping from a loopback on ME3800 to the 9000 (both on a VRF).
regarding the core and mVPN i'm using SSM/MDT and the control plane seems to be happy. even the tunnel interface is up on the ME3800 for traffic within the mVPN. within the mVPN i'm using BSR (ASR9k=RP and ME3800 knows about it).
I have a loopback on ME3800 which i can multicast-ping, via an igmp join. I have the same setup on the ASR, but i cannot simulate to the join on the loopback no the ASR from either the ME3800 nor the ASR.
3800_sw_pruebas#show ip pim vrf mcast rp mapp
PIM Group-to-RP Mappings
Group(s) 224.0.0.0/4
  RP 10.10.10.2 (?), v2 <---So, Control plane within mVPN works.
    Info source: 10.10.10.2 (?), via bootstrap, priority 192, holdtime 150
         Uptime: 00:10:47, expires: 00:01:38
3800_sw_pruebas#ping vrf mcast 225.0.0.1
Sending 1, 100-byte ICMP Echos to 225.0.0.1, timeout is 2 seconds:
Reply to request 0 from 10.10.10.1, 1 ms
3800_sw_pruebas#ping vrf mcast 225.0.0.2
Sending 1, 100-byte ICMP Echos to 225.0.0.2, timeout is 2 seconds:
.     <----multicast ping towards loopback on ASR9k.
3800_sw_pruebas#show run int loo1000
Building configuration...
Current configuration : 141 bytes
interface Loopback1000
! interface local to the ME3800
vrf forwarding mcast
ip address 10.10.10.1 255.255.255.255
ip pim sparse-mode
ip igmp join-group 225.0.0.1
end
3800_sw_pruebas#ping vrf mcast 10.10.10.2
!ipv4 ping towards loopback on ASR9k
Sending 5, 100-byte ICMP Echos to 10.10.10.2, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/1/4 ms
3800_sw_pruebas#
Now on the ASR9k:
RP/0/RSP0/CPU0:ASR_TEST#show run int loo1000
Thu Jun 20 17:53:02.583 CST
vrf mcast
ipv4 address 10.10.10.2 255.255.255.255
RP/0/RSP0/CPU0:ASR_TEST#show run router igmp
Thu Jun 20 17:53:55.838 CST
router igmp
vrf mcast
   join-group 224.1.1.1
   join-group 225.0.0.2
RP/0/RSP0/CPU0:ASR_TEST#show run multicast-routing
Thu Jun 20 17:53:05.609 CST
multicast-routing
address-family ipv4
  mdt source Loopback0
  interface all enable
vrf mcast
  address-family ipv4
   mdt data 232.232.2.0/24
   mdt default ipv4 232.232.0.1
RP/0/RSP0/CPU0:ASR_TEST#show mrib vrf mcast route
Thu Jun 20 17:53:28.364 CST
IP Multicast Routing Information Base
Entry flags: L - Domain-Local Source, E - External Source to the Domain,
    C - Directly-Connected Check, S - Signal, IA - Inherit Accept,
    IF - Inherit From, D - Drop, MA - MDT Address, ME - MDT Encap,
    MD - MDT Decap, MT - MDT Threshold Crossed, MH - MDT interface handle
    CD - Conditional Decap, MPLS - MPLS Decap, MF - MPLS Encap, EX - Extranet
    MoFE - MoFRR Enabled, MoFS - MoFRR State
Interface flags: F - Forward, A - Accept, IC - Internal Copy,
    NS - Negate Signal, DP - Don't Preserve, SP - Signal Present,
    II - Internal Interest, ID - Internal Disinterest, LI - Local Interest,
    LD - Local Disinterest, DI - Decapsulation Interface
    EI - Encapsulation Interface, MI - MDT Interface, LVIF - MPLS Encap,
    EX - Extranet, A2 - Secondary Accept
(*,224.0.0.0/4) RPF nbr: 10.10.10.2 Flags: L C
  Up: 05:45:42
  Outgoing Interface List
    Un:0x8000220 Flags: NS DI, Up: 05:45:42
    Decapstunnel3 Flags: NS DI, Up: 02:49:45
(*,224.0.0.0/24) Flags: D
  Up: 05:52:30
(*,224.0.1.39) Flags: S
  Up: 05:52:30
(*,224.0.1.40) Flags: S
  Up: 05:52:30
(*,224.1.1.1) RPF nbr: 10.10.10.2 Flags: C
  Up: 01:22:42
  Incoming Interface List
    Decapstunnel3 Flags: A NS, Up: 01:22:42
    Loopback1000 Flags: F IC NS II LI, Up: 01:22:42
(*,225.0.0.1) RPF nbr: 10.10.10.2 Flags: C
  Up: 00:15:30
    Decapstunnel3 Flags: A, Up: 00:15:30
    mdtmcast Flags: F NS MI, Up: 00:15:30
(*,225.0.0.2) RPF nbr: 10.10.10.2 Flags: C
  Up: 02:51:00
    Decapstunnel3 Flags: A NS, Up: 02:49:45
    Loopback1000 Flags: F IC NS II LI, Up: 02:51:00
(10.10.10.1,225.0.0.2) RPF nbr: 10.10.10.2 Flags: L
  Up: 00:06:45
    Decapstunnel3 Flags: A, Up: 00:06:45
    mdtmcast Flags: NS MI, Up: 00:06:45
    Loopback1000 Flags: F IC NS, Up: 00:06:45
(*,232.0.0.0/8) Flags: D
  Up: 05:52:30
now, AFAICT,control plane i correct, so I tried the ASR9k which is the BSR and RP within the vrf and when pinging the local multicast group (225.0.0.2) from the ASR9k I get:
RP/0/RSP0/CPU0:ASR_TEST#ping vrf mcast 225.0.0.2
Thu Jun 20 17:56:08.714 CST
Mdef cons get failed for VRF 0x60000001 - No such process
Basically my only question is: has anybody seen this error message? The most basic test for me would be to join a group in my own RP and try to ping it locally on the VRF, but this doesn't work. Any ideas?
TIA,
c.
Bryan Garland
Carlos,
When doing a ping in XR to a mcast address be sure to specify a source address.  For example:
ping vrf mcast 225.0.0.2 source loopback1000
Bryan
