ATA 187 register CME 9.0
huanng.isp
Dear all,
I check cisco document and found that, Cisco CME 9.0 support ATA 187 to connect fax/phone
I try to config SIP as bellow :
voice register global
mode cme
source-address 10.17.30.14 port 5060
max-dn 20
max-pool 20
tftp-path flash:
create profile sync 0086112851333914
voice register dn  1
number 8556
voice register dn  2
number 8557
voice register pool  1
id mac 0C85.25A6.9845
type ATA-187
number 1 dn 1
codec g711ulaw
voice register pool  2
id mac 8525.A698.4501
type ATA-187
number 1 dn 2
codec g711ulaw
But the ATA 187 cannot register with CME 9.0
i did debug command "debug tftp events" and found the error as below:
Dec 28 02:09:48.153: TFTP: Looking for CTLSEP0C8525A69845.tlv
Dec 28 02:09:48.389: TFTP: Looking for ATA0C8525A69845.cnf.xml
Dec 28 02:09:48.389: TFTP: Opened system:/its/vrf1/ATADefault.cnf.xml, fd 4, size 403 for process 153
Dec 28 02:09:48.393: TFTP: Finished system:/its/vrf1/ATADefault.cnf.xml, time 00:00:00 for process 153
Dec 28 02:09:48.905: TFTP: Looking for CTLSEP8525A6984501.tlv
Dec 28 02:09:49.125: TFTP: Looking for ATA8525A6984501.cnf.xml
Anyone who can help me with this issue
Minh
6 Replies 6
huanng.isp
Problem has been fixed
What did you do to address this?  I'm having a similar problem although i'm trying to SCCP register the ata
ATA 187 is supported with CME 9.0 only as SIP Endpoint not SCCP. Pls refer http://www.cisco.com/en/US/partner/docs/voice_ip_comm/cucme/requirements/guide/cme90spc.html
Pls rate the post if it helps.
GP.
Care to elaborate on how you fixed the problem. As of right now Cisco's documentation state 9.22 works. However there isn't a 9.22 firmware file available for download. There is a 9.23.1, but it appears to be for communications manager. Any help would be much appreciated regarding firmware files download link, tftp-sever commands, and telephony-service loads command used to fix the problem.
For ATA, phones, etc. fimware is the same for CM or CME.
So 9.23 is newer than 9.22 and that is what one would try first.
spazziani
Hi huanng.isp
What is version of ATA 187 ? In the documentation is showing that we need the version 9.2.2 but I can't find the firmware on the cisco's site.
What are your IOS version of the router to support the cucme 9.0 ?
Vinicius S Ramos
