cme order
mostafamossad
i need to know the part number which i can use to order the the cme4.1 i need the part number and the cost
paolo bevilacqua
CME is sold as a bundle with a router or CU500 so you need to specify which model you want.
Cost information is always provided by the reseller, or go to the leading auction site to get an idea.
Paolo,
But say for example you buy ISR security bundle but later decide you want to use the router with CME. I guess we need to know the part name for the set of files required. Essentially it will be licence with authorized download - na?
Ajaz
Yes there are upgrade order codes but again you need to mention on which platform and which upgrade, these codes and price are provided by the reseller as not available for general order.
