CUCM integrate CME
ricardorojas123
I need integrate the Cisco Call Manager with a Cisco Call Manager Express. Do I need to do the following tasks?
* In the CCME add a new dial-peer type voip, with the session target the IP Address of the Call Manager.
* In the CCM add this CME as H.323 Gateway and create a new Route Pattern.
This is correct ?
7 Replies 7
This is correct.
Hope that helped, if so please rate.
i have the same issue.
but cant get work.
someone said that the CUCM cant connect to the CCME, the only way is through "Cisco Unified Border Element" that can be the same gateway on ccme.
that right ?
but cant get work.
that right ?
You certainly can, just do as Ricardo mentioned
no need for CUBE
java
if this helps, please rate
java
I was under the impression that better results are possible defining CME as inter-cluster trunk, not GW.
This is a pretty common misconception. It will mostly work, and you probably won't have any problems. But, there's a high probability for some weird issues to come up, and some unexpected results.
It's easier to think of it like this:
H323 intercluster trunk: Cisco proprietary H323 (only between CCMs)
H323 gateway: ITU specification H.323
H323 intercluster GK controlled: Cisco proprietary h323 with a GK in the middle. CCM-GK-CCM
CME doesn't run any of the proprietary H323 information that CCM uses.
-nick
i fix the problem.
just put this command : h323-gateway voip bind srcaddr int the interface on the ccme.
