Migrating from CM 6.1.3 to CM 9.X
waqas sardar
Dear Team
1. We are migrating from CM 6.1.3.1000-16 to CM 9.X. I am using following path:
2. Backup the current CM 6.1.3.
3. Fresh Installed CM 6.1.3.1000-16 on the VM machine
4. Restore the old CM 6.1.3 backup on fresh CM 6.1.3.1000-16 in VM.
5. Upload the licenses.
6. Upgrade to CM 6.1.5
7. Upgrading direct from CM 6.1.5 to CM 9.X.
Anyone can please answer, is this path is correct?
17 Replies 17
Manish Gogna
CUCM 6.1.3 on VMware is not supported. You will need to upgrade to cucm 6.1.4 or 6.1.5 first on MCS and then follow the Jump Upgrade procedure as decsribed below
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/rel_notes/9_1_2/CUCM_BK_C9FFFCD0_00_cucm-release-notes-912_chapter_0100.html#CUCM_RF_J9359DDD_00
Manish
So basically the process would be:
Upgrade to version 6.1.4 or 6.1.5 on MCS
DRS Backup
Build same version of 6.1.4 or 6.1.5 on UCS
Restore the Backup
Upgrade to 9.x
Manish
Hi Waqas,
In addition to what Manush has said[+5] , u can also refer the presentation on Jump Upgrade.
https://supportforums.cisco.com/docs/DOC-34350
regds,
aman
Nice link for those who are not aware about the various D29 options [+5].
Manish
@ Manish
I already fresh installed 6.1.3 on the UCS and its working fine .
What are  the issues if i continous the same path?
Hi Waqas,
Installing cucm 6.1.3 on vmware is not TAC or BU supported as it has not been tested. Even if it works fine, TAC or BU will not support this installation as per the documentation which clearly says that only 6.1.4 or 6.1.5 ( or 7.1.3 / 5 ) can be used on vmware for jump upgrade to 9.x. So, i would suggest upgrading to 6.1.4 on MCS first and then restoring its backup on a freshly built 6.1.4 on vmware so that your installation is TAC and BU supported.
Manish
I can only restore backup on publisher and then reinstall subcriber ?
If you're going to use the jump upgrade option, you need to rebuild the whole live cluster in the lab.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
@ Jaime Valencia
2. upgrade the current CM 6.1.3 to CM 6.1.5 on MCS  and DRS.
3. Fresh Installed CM 6.1.5 on the VM machine.(6.1.5 is VM supported  ? )
4. Restore the old CM 6.1.5 backup on fresh CM 6.1.5 in VM.
5. Upgrading direct from CM 6.1.5 to CM 9.X.
Hi Waqas,
all points are  correct.
for point 5, u need to have cop files uploaded in call manager servers, depending on you are upgrading to restricted or unrestricted version of 9.x
regds,
aman
@aman
Hi Waqas,
please refer the link provided on page 11, 12 and 13. this is what is JUMP upgrade.
regds,
aman
Some 6.1(x) and 7.1(x) images are supported on VMware ONLY for the jump upgrade procedure
java
java
I have tried jump upgrade but Pub crashed every time by following error
*** An error occurred during the file system check.
*** Dropping you to a shell; the system will reboot
*** when you leave the shell.
Give root password for maintenance
(or type Control-D to continue):
cisco tac said its bug:
https://tools.cisco.com/bugsearch/bug/CSCui85967
NTP is configurered perfectly and also checked by command utile diagnose test.
how can get the complete traces n logs during the upgrdation process.
