ā01-16-2014 06:17 PM - edited ā03-16-2019 09:18 PM
Dear Team
1. We are migrating from CM 6.1.3.1000-16 to CM 9.X. I am using following path:
2. Backup the current CM 6.1.3.
3. Fresh Installed CM 6.1.3.1000-16 on the VM machine
4. Restore the old CM 6.1.3 backup on fresh CM 6.1.3.1000-16 in VM.
5. Upload the licenses.
6. Upgrade to CM 6.1.5
7. Upgrading direct from CM 6.1.5 to CM 9.X.
Anyone can please answer, is this path is correct?
ā01-16-2014 07:00 PM
CUCM 6.1.3 on VMware is not supported. You will need to upgrade to cucm 6.1.4 or 6.1.5 first on MCS and then follow the Jump Upgrade procedure as decsribed below
Manish
ā01-16-2014 07:02 PM
So basically the process would be:
Upgrade to version 6.1.4 or 6.1.5 on MCS
DRS Backup
Build same version of 6.1.4 or 6.1.5 on UCS
Restore the Backup
Upgrade to 9.x
Manish
ā01-16-2014 07:29 PM
Hi Waqas,
In addition to what Manush has said[+5] , u can also refer the presentation on Jump Upgrade.
https://supportforums.cisco.com/docs/DOC-34350
regds,
aman
ā01-16-2014 07:43 PM
Nice link for those who are not aware about the various D29 options [+5].
Manish
ā01-17-2014 12:14 AM
@ Manish
I already fresh installed 6.1.3 on the UCS and its working fine .
What are the issues if i continous the same path?
ā01-17-2014 12:19 AM
Hi Waqas,
Installing cucm 6.1.3 on vmware is not TAC or BU supported as it has not been tested. Even if it works fine, TAC or BU will not support this installation as per the documentation which clearly says that only 6.1.4 or 6.1.5 ( or 7.1.3 / 5 ) can be used on vmware for jump upgrade to 9.x. So, i would suggest upgrading to 6.1.4 on MCS first and then restoring its backup on a freshly built 6.1.4 on vmware so that your installation is TAC and BU supported.
Manish
ā01-21-2014 10:44 AM
I can only restore backup on publisher and then reinstall subcriber ?
ā01-21-2014 11:54 AM
If you're going to use the jump upgrade option, you need to rebuild the whole live cluster in the lab.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
ā01-22-2014 03:14 AM
2. upgrade the current CM 6.1.3 to CM 6.1.5 on MCS and DRS.
3. Fresh Installed CM 6.1.5 on the VM machine.(6.1.5 is VM supported ? )
4. Restore the old CM 6.1.5 backup on fresh CM 6.1.5 in VM.
5. Upgrading direct from CM 6.1.5 to CM 9.X.
ā01-22-2014 03:21 AM
Hi Waqas,
all points are correct.
for point 5, u need to have cop files uploaded in call manager servers, depending on you are upgrading to restricted or unrestricted version of 9.x
regds,
aman
ā01-22-2014 05:44 AM
@aman
ā01-22-2014 05:52 AM
Hi Waqas,
please refer the link provided on page 11, 12 and 13. this is what is JUMP upgrade.
regds,
aman
ā01-22-2014 06:20 AM
Some 6.1(x) and 7.1(x) images are supported on VMware ONLY for the jump upgrade procedure
java
ā01-29-2014 08:33 AM
I have tried jump upgrade but Pub crashed every time by following error
*** An error occurred during the file system check.
*** Dropping you to a shell; the system will reboot
*** when you leave the shell.
Give root password for maintenance
(or type Control-D to continue):
cisco tac said its bug:
https://tools.cisco.com/bugsearch/bug/CSCui85967
NTP is configurered perfectly and also checked by command utile diagnose test.
how can get the complete traces n logs during the upgrdation process.
