05-17-2008 11:23 AM - edited 03-15-2019 10:43 AM
I have a UC520 with Cisco IOS Software, UC500 Software (UC500-ADVIPSERVICESK9-M), Version 12.4(11)XW7, RELEASE SOFTWARE (fc2).
I have installed a VIC2-2BRI-NT/TE interface Cards in UC520, now i have 4 ISDN Basic Rate interfaces.
i want to use one of the 4 interfaces as Internal ISDN for a FAX-Server on MS Windows SBS 2003, (with a Eicon BRI Card).
how cann i do it ? with CCA 1.6 is not passible or i dont how.
Thanks for your help
Jan
05-17-2008 11:30 AM
first of all you might not even need the eicon card. CME/CUe can receive/send fax, convert to email, even on a per-user basis.
This said, you cannot use the CCA for anything more than basic configuration. This one would require you prepare crossed BRI cables, then configure like:
http://www.cisco.com/en/US/tech/tk652/tk653/technologies_configuration_example09186a008010ef6c.shtml
05-18-2008 12:59 AM
Thanks for your very fast Answer,
How can i configure the UC520 for recive/send Fax ? do you have a link for a Document.
How work the receive/send fax on CME/CUE ?
i have multiple ISDN-Nr (MSN) from ISP and i want to use one of the number for fax receiving.
how cann i send a fax from Win-PC-Client ?
Is a FAX-Server oder Network-Modem Emulation on UC520 ?
Best Regards und Thanks for your help
Jan
05-18-2008 01:24 AM
do you have a qualified partner helping you with the uc500 ? That is very necessary most most advanced configurations. You may loose a lot of time and get frustrated when you have no experience in these things. For fax relay, see:
http://www.uc500.com/fax-email-using-uc500-or-cme
More information is in cue and cme system administrator guides.
As a recogniotn to tose providing answers, please rate useful posts with the scrollbox below!
