UCM7 TFTP cant find .loads file
balitewiczp
Level 2
Level 2
recently uploaded cmterm-7941_7961-sccp.8-4-4.cop.sgn to my cucm7 cluster. I got complete from file upload. Now RTMT trace is saying it cant find the .loads file Any thoughts?
6 Replies 6
Jaime Valencia
did you uploaded the file to all the TFTP servers???
java
if this helps, please rate
java
no, just the primary. I'll try the backup also. thanks
found the problem. I uploaded it through the web gui, which is my pub, but my tftp servers are off subs, and the file is not in the tftp directory.
whats the best way to copy individual files?
install the file but log in to the SUBS, just below the install option is the TFTP management
java
java
how do I get the individual files from the .sgn file
got it. downloaded the zip file, and tftp them individually. thanks for your help
