dcnm install with red hat X11
fd_case17
Hello I would like to know if i can install dcnm for red hat with X11 forwarding ,
X11 is working ,
but I can't lauch .bin
here the result:
sh dcnm-installer-x64-linux.6.3.2.bin
Preparing to install...
Extracting the JRE from the installer archive...
Unpacking the JRE...
Extracting the installation resources from the installer archive...
Configuring the installer for this system's environment...
Launching installer...
Graphical installers are not supported by the VM. The console mode will be used instead...
Installer User Interface Mode Not Supported
The valid UI modes identifiers are GUI, and Silent.  By default installer will run in GUI mode.  If you are running the installer in GUI mode, X windows resources should be available to display the GUI installer.   It is not possible to telnet or ssh and install DCNM in GUI mode.
thanks for your answer,
0 Replies 0
