SSH issues with LMS 3.1
bevan.barry
Hi jclarke,
Browsing through the threads I saw that a solution was posted for LMS 2.6. Looks like the issue is with the version of java. The version I've got running is 1.6.0.50 and I'm now seeing anywhere where I can type in the command with the path to the ssh client. Could you please help!
Thanks.
10 Replies 10
Joe Clarke
You don't with Java Web Start. Instead, you need to create a campus.properties file in your home directory on your client. This file should have one line:
CMSSH=PATH_TO_SSH
Where PATH_TO_SSH is the fully-qualified path to your SSH client. For example:
CMSSH=C:\\PuTTY\PuTTY.exe
After doing this, restart your browser.
I should also add that you'll need Campus Manager 5.1.1 in order for this to work properly. CM 5.1.1 is downloadable through Common Services > Software Center > Software Update.
Hi jc,
Ok now downloading 5.1.1. I have version 5.1.0 running What are the java config though?
Bevan
There is nothing that needs to be configured Java-wise. You just need to be using Java 1.6.0_5.
Going to test this out in a few mins as 5.1.1 is still downloading. How would LMS know which ssh client to use?
It knows because you tell it in the campus.properties file I mentioned previously. LMS will use that SSH client. This file is configured on a per-user, per-client basis.
Sorry only now seeing that previous post.
I had a typo. The example should read:
CMSSH=C:\\PuTTY\\PuTTY.exe
Cool...I'll give this a go in a bit and let yu know how I get on. The software update failed so had to start it again.
Thanks JC! All is now well.
Loving the service by the way!
Bevan
