ISDN E1 PRI VOIP
jimihendrix1
I am configuring an ISDN E1 PRI Connection
(1/2 Port Channelized T1/E1 PRI Network Module)
When I configure the E1 controller example add the framing and pri-group timelots in the E1 controller. The voice port {voice-port 1/0:15 in my case}is not created for me to point my pots dial-peers.when I do a show voice port summary its not shown but when i do a show ip interface brief serial 1/0:15 is up. The conclusion is its not creating the voice port after I have entered the pri-group timeslots command. Please help. Thanks
19 Replies 19
Your are right!Thank you so much Nick for your help. I truly am a big fan. Could you recommend a replacement part number. I assume I should go for NM-HDV2-2T1/E1 any suggestions.
I wouldn't go with the NM-HDV, they use an older model DSP.
I would stick with straight PVMD2-X and VWIC-T1 cards.
hth,
nick
Nick do you suggest VWIC-2MFT-E1
Yes, it's a standard card with full feature support.
Thank you once again for your support Nick.
