05-30-2006 08:53 AM - edited 03-03-2019 03:25 AM
It's my understanding that the 4503 should recognize the new switch blade without configuration, is this correct?
Andy
05-30-2006 09:07 AM
Hi Andy,
You are correct, it will recongnize it as long as it has the minimum required IOS to support the module.
Please Check the link below for minimum and recomended cisco IOS software.
http://www.cisco.com/univercd/cc/td/doc/product/lan/cat4000/relnotes/ol_5184.htm#wp16938
HTH, Please rate if it does.
-amit singh
05-30-2006 11:47 AM
Apparently the 4503 is running CatOS judging from this output;
2nd-sw01> (enable) sho version
WS-C4503 Software, Version NmpSW: 7.4(2)
Copyright (c) 1995-2002 by Cisco Systems, Inc.
NMP S/W compiled on Oct 8 2002, 18:12:59
GSP S/W compiled on Oct 08 2002, 15:54:51
System Bootstrap Version: 5.4(1)
Do I need to move to a Cisco IOS?
Andy
05-30-2006 01:48 PM
Whats the card number you are installing ?
05-30-2006 01:50 PM
The card number is WS-X4548-GB-RJ45
