New 48 port blade in Cat4503
averheaghe
It's my understanding that the 4503 should recognize the new switch blade without configuration, is this correct?
Andy
amit-singh
Level 8
Level 8
Hi Andy,
You are correct, it will recongnize it as long as it has the minimum required IOS to support the module.
Please Check the link below for minimum and recomended cisco IOS software.
http://www.cisco.com/univercd/cc/td/doc/product/lan/cat4000/relnotes/ol_5184.htm#wp16938
HTH, Please rate if it does.
-amit singh
Apparently the 4503 is running CatOS judging from this output;
2nd-sw01> (enable) sho version
WS-C4503 Software, Version NmpSW: 7.4(2)
Copyright (c) 1995-2002 by Cisco Systems, Inc.
NMP S/W compiled on Oct 8 2002, 18:12:59
GSP S/W compiled on Oct 08 2002, 15:54:51
System Bootstrap Version: 5.4(1)
Do I need to move to a Cisco IOS?
Andy
Whats the card number you are installing ?
The card number is WS-X4548-GB-RJ45
