04-12-2004 10:13 AM - edited 03-09-2019 07:02 AM
I am recieving the following error in the event log of my csa server:
Product license for profiler is invalid or has expired.
Is this a separate lic?
I do not even see profiler anywhere in the menus.
Can someone please shed some light on this for me?
Frank
04-12-2004 11:38 AM
Are you running a demo?
I saw the same message, however I think it's leftover from before Cisco purchased it.
The profiler is used to analyze the behaviour of an application, such as what system calls it makes, ports it uses etc. It's a way of introducing an application to your environment without CSA blocking/complaining about it while you figure out the appropriate ruleset for it.
04-13-2004 06:33 AM
No I am not running a demo, I have uploaded licenses for CW common services, CSA Management console, and agent licenses.
Are there any others I need?
Frank
04-14-2004 08:23 AM
I too am having the same error message after installing the CSA console and agent licenses. I'll keep searching for a clue but if anyone has the answer please post it.
Alex Tatistcheff
04-14-2004 09:47 AM
TAC told me to upgrade to CSA 4.0.1.
It solved my problem
04-14-2004 02:35 PM
The message you are recieveing is indicating that the Profiler Application License is Invalid. Profiler is actually another purchase, in addition to the Agent Licenses. You can't see the Profiler option in the menu because it is not enabled until the license is added. You can contact your Cisco Rep for Pricing. The upgrade the 4.0.1 simply supressed the message- it didnt fix a problem, because there was no problem.
Also, Profiler was called Stormfront before Cisco picked up Okena.
