FWSM and SIP
liamkennedy
i want to allow inbound call initiation for blueface through our FWSM. I have fixup sip 5060 configured - I assume I need to allow UDP port 5060 on my inbound access-list as well, yes? Do I need to allow TCP 5060 as well?
thanks for any help.
Fernando_Meza
Level 7
Level 7
Hi .. yes I believe you need to allow UDP and TCP 5060 .. once the inspection is done then the firewall will open secondary ports as need it.
I hope it helps ... please rate if it does !!!
