04-27-2005 12:47 PM - edited 03-09-2019 11:05 AM
I am trying to connect two sites with VPN 3000 concentrators and IPSec tunnel. I've done this several times with other clients sucessfully but not this time. I get this strange IKE error in phase 1.
"received an unencrypted packet when crypto active!! Dropping packet."
I checked the connect settings and we are all using same encryption type and all. Where should I start loolking? What are the possible cause of such error?
Thanks.
dj
04-27-2005 12:54 PM
Problem solved. It was mismatched pre-shared key!!!
11-11-2005 01:29 PM
This is a good answer.
I spent quite a while debugging a connection between a 3005 concentrator and a Checkpoint firewall at a remote site. All the settings looked fine, but phase 1 kept failing and I noticed the above error.
Suggested to remote admin that we change the PSK and the tunnel came up right away.
