10-17-2008 12:18 AM
Hi,we have a 7206vxr that is used as a voice router,i am getting continous logs on my router:
Oct 17 08:02:54: %DSPRM-5-UPDOWN: DSP 15 in slot 4, changed state to up
Oct 17 08:03:06: %DSPRM-5-KEEPALIVE: DSP 15 in slot 4, NOT RESPONDING - auto restart(5551 time
s)
Oct 17 08:03:07: %DSPRM-5-UPDOWN: DSP 15 in slot 4, changed state to up
Oct 17 08:03:19: %DSPRM-5-KEEPALIVE: DSP 15 in slot 4, NOT RESPONDING - auto restart(5552 time
s)
Oct 17 08:03:20: %DSPRM-5-UPDOWN: DSP 15 in slot 4, changed state to up
Oct 17 08:03:32: %DSPRM-5-KEEPALIVE: DSP 15 in slot 4, NOT RESPONDING - auto restart(5553 time
it is happening for the last 2-3 hours.
what needs to be done.
10-23-2008 10:30 AM
If the error message happened when the DSP is timing out. It may indeed be a bad dsp, as well as could be a faulty slot where the dsp is seated, or a software bug. Can you please send to me a copy of the following from the router:
show ver
show run
show diag
show log
10-23-2008 07:59 PM
01-25-2009 04:40 PM
can u reset te dsp/reload the router and check again
01-25-2009 06:16 PM
if dsp reload do not work,
try replacing it with other module and see if it works.
