polycom ip4000
jwcasey007
has anybody successfully intergrated a polycom conferencing unit onto a UC540.
Polycom:
http://www.polycom.com/global/documents/support/user/products/voice/soundstation_ip4000_user_guide_sip_2.0.x.pdf
We absolutely cannot get this to register.  If anybody's had success can you share your configs??
Please & thanks!
Steven Smith
Level 7
Level 7
This document will give you the idea of what to do on the UC500 side.
https://supportforums.cisco.com/docs/DOC-9465
I haven't used this particular phone before, so I am not sure how it would work on the phone configuration side.
jwcasey007
Thanks Steve,
Looks like that doc is for an anlog device. This polycom is a SIP device...
You are correct, but the process is the same.  The analog device is a SIP endpoint.  The UC500 doesn't know what type of device it is be configured.  This guide would help get the config on the UC500 correct.  The part that concerns the SPA8000 web page would be different.  You would need to figure that part out on your polycom.
Perfect.  We'll give this a try right now.
Thanks Steven
